Desktop/Copy of GPS_TRACE/SRC/status.h File Reference
This graph shows which files directly or indirectly include this file:
Go to the source code of this file.
Functions
void setFixstate (char c)
int getFixstate ()
 Sets the status of GPS fix (fixstate).
void showFixstate ()
 Returns the value of GPS fix (fixstate).
void setNS_indicator (char c)
 Displays the fix state on LCD.
char getNS_indicator ()
 Sets the North/South inidicator.
char getEW_indicator ()
 Gets the North/South inidicator.
void setEW_indicator (char c)
 Gets the East/West inidicator.
char * getLatitude ()
 Sets the East/West inidicator.
void setLatitude (char *s)
 Returns a char pointer the the N degree.
char * getLongitude ()
 Sets GPS Latitude.
void setLongitude (char *s)
 Gets GPS Longitude.
void FormatLongitude ()
 Sets GPS Longitude.
void FormatLatitude ()
 Formats GPS Latitude van ddmm.mmmm naar DD°MM.mmm.
void showLatitudeFormatted ()
 Formats GPS Longitude van dddmm.mmmm naar DD°MM.mmm.
void showLongitudeFormatted ()
 Shows GPS Latitude in DD°MM.mmm format on LCD.
char * getLatitudeFormatted ()
 Shows GPS Longitude in DD°MM.mmm format on LCD.
char * getLongitudeFormatted ()
void ReportPosition ()
Variables
int fixstate
char NSindicator
 Represents the fixstate of the GPS-module.
char EWindicator
 Represents the Latitude North/South indicator.
char Latitude [10]
 Represents the Longitude East/West indicator.
char LatitudeFormatted [15]
 Represents the Latitude in ddmm.mmmm format.
char Longitude [10]
 Represents the Latitude in DD°MM.mmm format.
char LongitudeFormatted [15]
 Represents the Longitude in dddmm.mmmm format.
Function Documentation
void FormatLatitude (  )
Parameters:
none
Returns:
none
Definition at line 114 of file status.c.
References Latitude, LatitudeFormatted, and NSindicator.
void FormatLongitude (  )
Sets GPS Longitude.
Parameters:
char *s (result)
Returns:
none
Definition at line 96 of file status.c.
References EWindicator, Longitude, and LongitudeFormatted.
char getEW_indicator (  )
Parameters:
none
Returns:
NSindicator (char)
Definition at line 70 of file status.c.
References EWindicator.
int getFixstate (  )
Parameters:
char c --> this is the result of getfield (5,2);
Returns:
none
Definition at line 10 of file status.c.
References fixstate.
char* getLatitude (  )
Parameters:
char c
Returns:
none
Definition at line 75 of file status.c.
References Latitude.
char* getLatitudeFormatted (  )
Parameters:
none
Returns:
none
Definition at line 131 of file status.c.
References LatitudeFormatted.
char* getLongitude (  )
Sets GPS Latitude.
Parameters:
char *s (result)
Returns:
none
Definition at line 86 of file status.c.
References Longitude.
char* getLongitudeFormatted (  )
Definition at line 136 of file status.c.
References LongitudeFormatted.
char getNS_indicator (  )
Parameters:
char c
Returns:
none
Definition at line 65 of file status.c.
References NSindicator.
void ReportPosition (  )
Definition at line 142 of file status.c.
References delay_ms(), getFixstate(), getLatitudeFormatted(), getLongitudeFormatted(), GSM_COMMAND, led_yellow_off(), uart0_putc(), and uart0_puts().
void setEW_indicator ( char  c  )
Parameters:
none
Returns:
EWindicator (char)
Definition at line 55 of file status.c.
void setFixstate ( char  c  )
Definition at line 15 of file status.c.
void setLatitude ( char *  s  )
Parameters:
none
Returns:
char* Latitude
Definition at line 80 of file status.c.
void setLongitude ( char *  s  )
Gets GPS Longitude.
Parameters:
none
Returns:
char* Longitude
Definition at line 91 of file status.c.
void setNS_indicator ( char  c  )
Parameters:
none
Returns:
none
Definition at line 60 of file status.c.
void showFixstate (  )
Parameters:
none
Returns:
1 or 0 --> 1 means fix, 0 means no fix
Definition at line 27 of file status.c.
References getFixstate(), lcd_gotoxy(), and lcd_puts().
void showLatitudeFormatted (  )
Parameters:
none
Returns:
none
Definition at line 42 of file status.c.
References getLatitudeFormatted(), lcd_gotoxy(), and lcd_puts().
void showLongitudeFormatted (  )
Parameters:
none
Returns:
none
Definition at line 49 of file status.c.
References getLongitudeFormatted(), lcd_gotoxy(), and lcd_puts().
Variable Documentation
char EWindicator
Definition at line 120 of file status.h.
Referenced by FormatLongitude(), getEW_indicator(), and setEW_indicator().
int fixstate
Definition at line 110 of file status.h.
Referenced by getFixstate(), and setFixstate().
char Latitude[10]
Definition at line 125 of file status.h.
Referenced by FormatLatitude(), getLatitude(), and setLatitude().
char LatitudeFormatted[15]
Definition at line 130 of file status.h.
Referenced by FormatLatitude(), and getLatitudeFormatted().
char Longitude[10]
Definition at line 136 of file status.h.
Referenced by FormatLongitude(), getLongitude(), and setLongitude().
char LongitudeFormatted[15]
Definition at line 141 of file status.h.
Referenced by FormatLongitude(), and getLongitudeFormatted().
char NSindicator
Definition at line 115 of file status.h.
Referenced by FormatLatitude(), getNS_indicator(), and setNS_indicator().
Generated on Fri Aug 17 13:50:57 2007 for GPS TRACE by  doxygen 1.5.3
